Boost Solenoid & Fuel Q...
You should be able to get vacuum caps from the parts place. You'll want to cap off the line that was going to the solenoid, but leave the one on the actuator open, as Bio said.
i knew not to cap off the actuator, but thanks for reminding me. i just capped it off w/ a bolt for now i didnt see any vac caps @ walmart where I work so ill pick some up when I go to the parts store next. thanx.
when you first start your car in the morning does it idle up and then stall out? i had this same problem and it was solved with the replacement of my maf sensor? not sure if thats helpful at all but there ya go
