boost overload?
jhazzy10
when im driving my boost bar in my DIC is reading that my car is always using the supercharger. When im sitting still it reads the bar being half way used. Is there a problem with my DIC? Or is my supercharger actually always being used? And if my supercharger is always being used, will that effect my MPG because it will always be shoving more air through my engine therefore it will use more gas right?
yes more gas = bigger bang. but really i would start to look for the reason its show boost at an idle 1 reason might be vacuum leak.
its like whenever im driving the bar is all over the place, i will have my car in cruise control on a road that isnt going up or down and the bar will be full and then 2 seconds later it will be like half way.
Check the vacuum line going to the map sensor. I've had the same thing happen and it was because the map sensor vacuum line that was disconnected
