Bogging
goldgp
Grocery Getter x2
Got my GTP i recently bought all put back together and i am having an issue...First i will give you the background info.It is a 97 with 105k on it,stainless headers( no cat or u bend of course),ported supercharger outlet,new ngk plugs and wires, K&N drop in filter and new vac lines and other general maintnence stuff.Stock pully and PCM and the boost bypass is stock. The car idles, starts and runs great driving normal. But if you are at a dead stop and you get on it, it will initially break the tires loose and then bogg down and loose power.Even when i bring the RPMs up to 15hundred or so it still boggs...:(Also as a side note, my tac doesnt move smooth and my traction controll is off like i have a bad CPS.Could be a bad wheel speed sensor tho as my hubs are shot...:)
Any advice would be real helpfull, and yes i did try the search bar:D
he doesnt have a cat.
kinda sounds like torque mangement is kicking in really hard to try and stop the wheel spin.
Does the car bog down if you hammer it from a 20 roll or higher???
Trac control does not engage, Trac off stays lit all the time.And come to think of it,it acts just like the trac control is getting it...i just ruled it out caus it SAYS its off, may not be tho.Thanx for the idea FFDP
Went and unhooked the speed sensors on the front wheels and walla,no bogg.I got a bad speed sensor causing the trac off light and abs light.I feel like a ree ree for dismissing the traction control as the problem just cause a light said it was off :th_frowning: Thanx for the post.
