Changing spark plugs one at a time to cure cylinder misfire condition is the beginning of a never ending saga that no one should EVER have to endure, but still, we do. I am going to try to save someone that grief, even if I can only help one soul.
Here is MY story.
I bought the 2000 GTP in Jan., 2008. No problem with engine light until Feb., 2010.
First time engine code P0303 (Cyl.3 misfire, AutoZone).
Cable terminal on the #3 Ignition pack was corroded. I did the minimum. I cleaned the Cable terminal. Engine light cleared. One week later,
Second time engine code P0303 (Cyl.3 misfire, AutoZone).
Cable terminal on the #3 Ignition pack was, still clean. Plug number #3 melted (and I DO MEAN Melted!) I failed to look at it the first time. Second time, I still did the minimum. I replaced the #3 plug (with a copper plug as ID by AutoZone) and #3 wire. Engine light cleared. Another week passed (can anyone finish this story before I can?).
Third time engine code P0301 (Cyl.1 misfire, AutoZone).
I did what everyone said I should have the first time (almost...).
I changed all the plugs and wires. (Except the one that was blocked by the front O2 sensor (stock exhaust setup, few here may still have). Engine light cleared. Not replacing all plugs the first time, big mistake. I failed to correctly ID the melted plug as "iridium", it was (AND SO WERE THE REMAINING PLUGS). So, I ran 1 new copper and 5 old "iridium" for about two weeks. Then, I made my second huge mistake. I ALMOST replaced ALL my plugs and wires with new copper, leaving the #6 "iridium" because it was the PITA plug behind the O2 sensor, I was quite sure nothing seriously wrong could come of it. I was right, I thought, until 1 month later.
Fourth time engine code P0306 (Cyl.6 misfire, AutoZone).
(This time it also flashes some time).
I think I am going to follow the advice of the guys here and replace ALL the plugs and ALL the wires TOMORROW!
I have already acquired the FREE loaner tool (for the PITA #6 plug).
I have decided on plugs from NGK, IRIDIUM IX, TR55IX, 7164 on a stock setup, for their longevity. No other mods, (quite yet). I have already acquired these.
I have decided on wires from ACCEL, 8MM Super Stock Spiral Wire, HI TEMP, BLUE Jacket, 5040B. I have already acquired these, also.
I have prepped my fuel system using SeaFoam for GAS engines.
And best of all I know I will not regret the “initial” expense because this has already been a PITA, to me. I sincerely hope this helps at least one person out there. I will try to update with details as they become available.
