Just replaced a broken valve spring on my 01 GTP (#1 on the exhaust side). Got it all back together and the car ran great, for about 20 miles.
First I got the blinking SES. Tried the car a bit later, solid SES at idle, idle is jumping around a bit. Under acceleration the steady SES becomes a blinking SES.
I know the normal things to check for plugs wires and coil packs (anyone know what ohm reading they should be) its almost 5 am here and I haven't checked any of it yet. So I will check all tomorrow(today).
My main concern is the valve spring I also replaced the seal on that valve. Could a problem with that valve be causing a steady SES at idle and then a blinking SES under load. It goes back to steady when there is no load on it.
Just looking for ideas of stuff to check other than the normal stuff.
