bandook
Donating Users
Ok, here is a visual example of what I've been dealing with. Hopefully u can understand my frustration, lol.
So I'm tuning open loop MAF using wideband error %. I was tuning the injectors I just installed, and i had everything going in the right direction. This photo is after a run, i
I made a tiny adjustment around 8000hz to richen up that spot. Save, flash, drive for 5 minutes and then I get this:
And it wanted to stay lean. I did find that a couple injector O-rings are leaking, so I'm fixing that now. But I had the same issue when I was using the 60# injectors. They could have been leaking too though, cause I had noticed a fuel smell especially after a quick deceleration to a stop. I'll report what I find after I get the o-rings replaced. Also pulled the FPR and it was a bit dirty, had some rust on the inside of the rail where the fpr sits in.
