225s are usually like just under 9" wide, what's the issue here?
LIES ! ! ! ^^^
If that were the case, the tire would go to the edge and drop straight down to the wheel, or almost straight to the wheel. Not protrude out at a 30* angle because its 1/2" short on either side. I know its not as bad as some have done. I also know you CAN truly stretch a 225 onto a 10" wheel, but that doesn't make it a good idea.
Specs for the tires are:
[TABLE="width: 100%"]
[TR]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Overall Width:[/TH]
[TD="class: vi-ia-attrColPadding"]8.90"[/TD]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Section Width:[/TH]
[TD="class: vi-ia-attrColPadding"]225[/TD]
[/TR]
[TR]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Load Range:[/TH]
[TD="class: vi-ia-attrColPadding"]Extra Load[/TD]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Aspect Ratio:[/TH]
[TD="class: vi-ia-attrColPadding"]40[/TD]
[/TR]
[TR]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]UTQG:[/TH]
[TD="class: vi-ia-attrColPadding"]360/A/A[/TD]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Rim Diameter:[/TH]
[TD="class: vi-ia-attrColPadding"]18[/TD]
[/TR]
[TR]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Measuring Rim Width:[/TH]
[TD="class: vi-ia-attrColPadding"]8"[/TD]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Load Index:[/TH]
[TD="class: vi-ia-attrColPadding"]82[/TD]
[/TR]
[TR]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Max Load:[/TH]
[TD="class: vi-ia-attrColPadding"]1389 lbs @ 50 psi[/TD]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Speed Index:[/TH]
[TD="class: vi-ia-attrColPadding"]V[/TD]
[/TR]
[TR]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Sidewall:[/TH]
[TD="class: vi-ia-attrColPadding"]Blackwall[/TD]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Overall Diameter:[/TH]
[TD="class: vi-ia-attrColPadding"]25.1"[/TD]
[/TR]
[TR]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Rim Width Range:[/TH]
[TD="class: vi-ia-attrColPadding"]7.50" - 9.00"[/TD]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Tread Depth:[/TH]
[TD="class: vi-ia-attrColPadding"]10.00/32"[/TD]
[/TR]
[TR]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Weight:[/TH]
[TD="class: vi-ia-attrColPadding"]22 lbs[/TD]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Part Brand:[/TH]
[TD="class: vi-ia-attrColPadding"]Toyo[/TD]
[/TR]
[TR]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Manufacturer Part Number:[/TH]
[TD="class: vi-ia-attrColPadding"]195450[/TD]
[TH="class: vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding, align: left"]Car Type:[/TH]
[TD="class: vi-ia-attrColPadding"]Passenger/Performance[/TD]
[/TR]
[/TABLE]
Its measuring rim width is 8" so on a 8.75" wide rim its pushing the limits of a 9" rim for a proper fit. It works, just stretched. A 245 would have been a better fit. Just sayin.
