bagged gp's
wow i can't read for **** when i drink
hmm 5" is alot tho. to start w/. i'm sure you could modify **** or get different struts to lay all out
5" is a lot, but it won't lay the frame on the ground. that is why i would run a bag over coil setup so i could drop it down farther than it would normally be mounted.
What's the ride quality on an airbag system?
depends on what kind of ride height you have to use in order to not rub. you can always run the bags at some sort of 'middle ground' pressure and they should ride great.
too low of pressure and it will be bouncy and squishy. too high of pressure and itll be rock hard and jarring. it's something you'd have to play with in order to get right, but that is why most modern air bag controllers have presets that you can program in them.
