VGPGT
The axles on the '97 GTP are larger in diameter than the '97 GT ????? Well I know they are on this GTP that I'm trying to put a GT motor and trans into.
How far into the trans does the axle shaft actually go in? Does anyone have a close up view showing the passenger side axle in the transmission?
After finding out this I took apart the inner CV boot, put the GT end on the axle and inserted it into the transmission, while doing this the boot separated because of the aftermarket boot clamp failed.
So I have the inner shaft either in the transmission or partially into the passenger side transmission - not sure... I think I heard the click of the lock ring but at the same time I noticed the boot had separated so I really don't know.
Funny thing is I tried to install the GTP axle for 10 minutes before doing outside in the snow to look at the GT carcass then noticing this is different.
I have not looked at the drivers side yet.
