Nates94
My grand prix has developed this hard left pull. I've dealt with this issue before on this car, but this time it's different.
If I make a left or right turn it constantly pulls to the left. Before I had a memory steer issue. I turn to the right it would go straight. Turn to the left it would pull left hard.
I got that fixed. Over the past couple of days this new pulling issue has gotten pretty bad. It takes quite a bit of strength to keep the car going straight.
This is the position my wheel needs to be in to keep the car going straight.
I've recently replaced tie rods, ball joints, spring plates, front struts, and calipers. I also replaced my front sway bar bushings, and control arm bushings. I had the car aligned after that and it was driving fine.
Now it's pulling again and I'm not sure what it is. Might be a bad belt in my left tire?
I'm at a loss. I've switched the tires and had no luck still pulls. It does take a lot of effort to keep it going straight. I don't really feel safe driving the car like this.
