cleangtp
Banned
I've posted this a few other places on this site but I want to hear all opinions. I've caught alot of flack from other sites about the intake I just put on my 98 gtp. Here is my setup, sorry for the bad quality pic.
Cost me $66 out the door with a $10 off coupon from advance. It's 4 inch tubing with a 45 degree bend, I tried the 22.5 degree bend but the filter was to big and was hitting I believe the cruise control. I bought one 3.5 to 4in coupler, bought a 7/8's holesaw bit for IAT, came with the grommet. K&N filter 4x9 inch very pleased. I actually saw on the butt dyno you can def feel the difference. Supercharger screams like a baby. I also had a old 45 degree elbow and since my car is a 98gtp I already had the triangle duct where the guys use the roof flashing. I attatched the 45 degree bend on the inside of the fenderwell to duct cold air right to the tip of the filter.
Now here's what another member on another site said about my intake. I don't totally agree with what was said at all, do you?"
DarkRelic » Mon May 17, 2010 10:49 am
"I hate to break it to you... although you made a free-er flowing intake, you actually failed by not making a box. It's been showed time and time again that Hot-Air Intakes are worse than the stock intake/airbox.
The radiator blows the hot engine air right into your air intake.... so instead of taking in air that is near ambient, you end up sucking in air that's usually 50-80 degrees above ambient, so when your supercharger (assuming a stock pulley) increases the air it's forcing into your intake manifold 150-200 degrees over ambient and then you add the extra ~50-80 degrees you are sucking in from the radiator you are doing more harm than good.
Yeah, stupid ricers who drive naturally aspirated cars can get away with hot air intakes. That's only because they don't have anything amplifying the temperature of the air the engine is taking in to begin with. you have a good start, now make yourself a box.
Oh and BTW, if you don't want your PCM to be bouncing around in your engine bay, get a chevy S-10 PCM tray."
Here's my response to the above post I have in quotations,
In no way shape or form was my stock air box/drop in paper filter out performing what I've got now, absolutely no way. Maybe at bringing in cooler temps but not flow, more air = more power. I'm going to brunswick tomorrow with a friends dad to dyno his supercharged prelude. You want me to take my stock air box dyno it, then put my setup on and dyno it? My filter is not even remotely in front of my radiator. The only time my setup would be sucking in those kind of temps is at a light or not moving. You ever wonder why when going over 35mph there's no need for fans to cool an engine? Same relevance here, especially with that stock junk air box being eliminated. If I relocate the coolant bottle it opens up even more air, not to mention from the reverse 45 degree elbow ducted to run air right to the filter on the inside of the fender.
I'm not debating that a box wouldn't out perform what I've got right now. Everyone knows cooler, dense air will always make more power. I'd totally agree with you if a car was NA but with a blower car it's different. Plus the stock air box eliminates the ability for air to flow thru the engine bay anyways, now it's wide open. The PCM isn't moving one centimeter the filter holds it down perfectly the way it is. I would like to have the PCM tray but in order for the PCM to lay flat I first need to buy a 99+ coolant bottle.
If I was good at fabricating I'd build a box but I'm not and I'm not spending $200-$300 on a box it is what it is.
Open cone 4x9 K&N > stock paper drop in
4inch pipe with 1 45 degree bend > 98 stock gtp airbox with 2 90 degree bends with corrugated tubing and 2 inch hole for air to flow thru
Flow > ambient temps especially on a modded car which I'm working on
$70 > $200-$350+ prices for a box
Next is headers, 1.95 roller rockers, cooler plugs, 180 thermo, aeroforce scangauge, 3.4 pulley, custom tune , when that's all done we will see where I'm at with knock retard and probably call it quites and focus my attention on suspension and brakes.
I'm welcome to any opinions good or bad. Thank you!
