Lawngoose
I know the response will be vac leak, but hear me out.
I took the car to the shop on monday to get it smoke tested. They could not find a leak. I sprayed everything I could. Even replaced some of the T's. Never affected idle.
Coolant/Oil levels are fine ever since my LIM change. But I had to replace a TB gasket cause I found a leak. Also, found one at the EGR block offplate, but I got it sealed now.
Since I can't find a leak after a thorough carb cleaner bath, what should I check next?
My LTFT's at 16.4 on idle on my "box tuned" pcm, however, when I scaled the MAF it gets/feels alot better. Only thing that looks bad is Decel...
Do you ONLY get 16.4 when you have a vac/exhaust leak? Or can it be attributed to other things... like adding headers...etc.
I have thoroughly read the 01+ fuel dump issue, and I have tried 98 files...etc with the same result.
Anyone in the Southeast wanna make some money before I put this thing in a ditch? LOL
