SyntheticShield
Well with the car out of commission and planning to yank the engine along with the tranny so I can rebuild the tranny and do some engine upgrades, Im wanting to do a complete AN fuel set up. Tank to rails. From the connection to the fuel pump, to the connection at the rails.
I know they make quick connect/disconnect AN fittings so I can connect to both the pump and rail without modification, what I dont have are all the part numbers and stuff I would need. Well I have a couple, but I want to make a complete list on what I will need so I can order everything and I also need to know what size SS Braided line I need.
I believe the feed line and return lines are different sizes, arent they? If so, what size fuel line do I need to get.
Anyway, if you have done a complete set up I would certainly appreciate pictures and part numbers. I havent decided if I will do after market rails yet because the only ones I would consider are PRJ's and they aren't cheap. Id rather do the lines now and save up for the fuel rails later since I could easily do those with everything back in the car.
I appreciate any and all help.
