I'm trying to get my low beams to work again. I have aftermarket head lights with halos and projectors for low beams and have HIDS in fogs, highs, and lows I also have relay harnesses for all of them. I've had this setup for a while. Two weeks ago I had my lows just stop working and took a look the next day to find that my relays had gotten water in them and caused a big amount of corrosion. My high beams worked fine but that relay was also screwed so I bought 2 new relays and put them in, I also changed the fuses in the harness for the hell of it. I found that the harness connection had a lot of corrosion build up in it so I sprayed it down with electrical cleaner and tried to wire brush it but the connections are tiny and I have nothing to get in there. So now I'm trying to figure out why it still won't work so I jump the relay harness (if your familiar with them they have a number 87 and 30 on it that I jumped, if your holding it while reading the diagram its the top and bottom connectors) and the low beams turned on just fine. I didn't keep it that way long as I was just testing it. Now when I put the relay back in it still doesn't work, so I tried to just slightly angle the tabs in different directions to produce a strong connection thinking maybe the connections inside the harness had loosened but still doesn't work. I have as well switched all relays back and fourth and swapped high and low ballistics and lows turned on fine but then highs didn't work. Am I missing something here? I believe I found where the issue is but no matter what I try to fix it I still can't get it work.... Is there anyway to pull the connections out of the end of the harness and clean them up?
