it sounds like thats the problem but im not 100% sure
so the tire has a slow leak?
if so get a spray bottle with some dish soap in it and water, pump the tire up to 60 psi, then spray the tire looking for bubbles.
also spray the bead of the tire good. ( tire to wheel area) those leak for sure sometimes.
once you find the hole, nail, screw, whatever it may be. you use a plug kit to fix it, or go to a tire shop and have it patched. costs more due to tire removal and re balancing it.
hot to cold wont be that drastic. balance may be out. even on a new tire, sometimes they f up.
make sure you get a high speed balance.
i just had a hub go bad, it had no play that i could feel. it was seizing up tho.
Not crazy. When I leave work in the morning and it's gotten cooler out I have a wobble too that goes away after a mile or so. Always assumed it was tires having a "flat" spot from the temperature change.
it would have to be really cold for that to happen. the one spot of the tire on the ground could have a harder spot due to being frozen hard.
if its over freezing id think that wont apply.
i have a gxp with brand new tires and new wheel hubs on the front at least. but i still have a wobble for about a mile. but i still have a little bit of a shake after that due to a bent rim (need to get new ones)![]()
when I bought my car it felt like a tire imbalance so I had the dealer look at it and they had the rim straightened out as it was bent, a bent rim I would think would never feel better until repaired
