CrazyGuy03
Just wondering if anyone has any advice before I go forward with a new set of tires
mods are as follows
kyb agx struts x4
tein springs
camber bolt in front struts
adjustable camber brackets in rear
(added 2 more washer behind each bolt on the brackets because last year the adjustment was at the max and the tire was still wearing the inside edge in the rear)
Tires are 225/40/18
Now last April everything suspension wise was replaced with new moog parts and I loaded them with poly bushings
*last week I noticed the inside of the front tires are now worn down to the belts! And the back inside tread was cupped.
Tbis was after I had it aligned following the work I did
so I just want to check - it's aligned again and before I get new tires again - any thoughts ?
thanks!!
mods are as follows
kyb agx struts x4
tein springs
Tires are 225/40/18
thanks!!
