medicmandan
If the hose is sucked in then it's under vacuum and about to start pulling through the overflow if the rad cap is working correctly. By opening the bleeder when you did you allowed air into the system then after the air comes in then coolant will come out a little bit.
open the bleeder either right after startup cold, or after the engine is warm. Then of no air comes out when it's warm leave it be.
Jeff
That makes sense. I'll let it cool down completely and start from the beginning. I found a write-up in the tech tips.
