Air to Air Intercooler....
Maybe I'm not understanding your goal, or I misread something...
How are you going to move the air through the IC System at a high rate of speed? With a turbo, the air is forced, but with just the supercharge pulling air in, the air will not be compressed until after it has passed through the intake, therefore it will nothave the same cooling effect.
I don't see this being cost effective or creating a greater result than A2W IC.
Fun Fact: Aluminum and Welding it are not cheap.
ok There are minorioties coming over and trying play in are field, i dont like it. thats why im here and no there.
Don't let him fool you, GTPpower knows his stuff. This is the guy that went 11s in the quarter mile in a GTP for under $2k in mods. He is also friendly and willing to help out almost anyone that asks for it.
Well could of fooled me with the readings in this thread. but hey dont judge a grand prix owner by the way they forum talk lol
Just to feed some more fact into this thread, the follwing is from this link: Water to air intercooler? - RX7Club.com
Remember alot of factory boosted cars have run water to air heat exchangers with much success. SVT Cobra, Bugatti Veryon, ZR1 Vette & many others. There are benifits & drawbacks to either system.
This I pulled from superchargersonline.com
An intercooler (sometimes referred to as an aftercooler) is designed to remove heat from the compressed air coming from the supecharger (or turbo) before it enters the engine's induction system. An intercooler works just lie a radiator - air is cooled by fins, bars, louvres, and plates inside the intercooler that are cooler than the compressed air coming from the supercharger. The reduction in air temperature increases the density of the air (more air molecules per cupic foot), which consequently increases your engine's ability to make more horsepower and torque. The decreased air temperature allows you to run more boost on a given octane of fuel before detonation occurs..
What's up with the terms?
The term 'intercooler' comes from days when they were first used on twin turbo aircraft engines. With two turbos, the air charge would get VERY hot - it was heated by the first turbo, then heated again by the second turbo. To combat this double temperature rise they placed a heat exchanger in between the two turbos and called it an "intercooler" because of its location in between two turbos. When this same kind of heat exchanger is used on a single turbo or supercharger, it is located after the supercharger, and should technically be called an "aftercooler" because of its location after the single turbo or supercharger. These terms didn't seem to stick, though. The term 'intercooler' caught on and became almost universal for all heat exchangers regardless of their position. The term 'aftercooler' became synonymous with air-to-water coolers because this is the term Vortech uses to describe their coolers, which are water cooled. So while technically incorrect, we will still use the popular terms 'intercooler' to mean any air-cooled charge cooler and 'aftercooler' to mean any water-cooled charge cooler.
Why Intercool?
There are several important benefits to intercooling that have resulted in their increased popularity in recent years. The most significant advantage is that intercooling increases the detonation threshhold because of the cooler air charge, meaning you can run more ignition advance for higher performance, or run lower octane fuel before experiencing detonation. This makes intercoolers very desirable for those looking to get the most out of their street vehicles on pump gasoline. The cooler air also allows your engine to run slightly cooler, reducing the chances of overheating. Intercoolers also enable your engine to produce more horsepower because of the denser air charge being delivered to the engine's combustion chamber.
Don't assume, however, that you can simply bolt an intercooler on to your supercharged engine and expect power gains with no other changes to the system. Intercoolers do create some internal drag causing a slight reduction in boost, and can also cause the engine to run lean (knock) due to the denser air charge. These problems are easily corrected and should not cause concern, however they cannot be ignored. Boost pressure can be brought back up (actually you'll probably want to run substantially more boost than you did with a non-intercooled application) using a smaller supercharger pulley. The smaller supercharger pulley will spin the supercharger faster and increase its output. Make sure your supercharger is designed to handle these higher boost levels. Correcting the air/fuel ratio to compensate for the denser air charge can be done with larger fuel injectors, recalibrated FMU, larger fuel pump, adjusting the mass air meter, etc.
Intercoolers... Aftercoolers... What's the difference?
In order for an intercooler to effectively cool the air that passes through it, the intercooler itself must be cooled by some external means. Most intercoolers are cooled just like your engine's radiator - air flows over the outside of the intercooler's fins, which in turn cool the air inside the intercooler - hence the name Air to Air Intercooler. Some intercoolers, however, are cooled by water instead of air, in which case they are generally called aftercoolers, or Air to Water Intercoolers. The benefit to an aftercooler is that air passing through it can be cooled more than in a traditional air/air intercooler if very cold water and ice are used to cool the intercooler - in fact, some aftercoolers chill the air to below ambient air temperatures even after it has been compressed by the supercharger. The reason aftercoolers are more effective in cooling the air charge is because water is a much better conductor of heat than air - in fact water conducts 4 times as much heat as air! The obvious drawback is that with time, the water will heat up to the temperature of the air passing through it, and its ability to cool incoming air goes away. Some aftercoolers, however, use a small radiator to cool the water that runs through the system, making them ideal for street use as well as racing. For drag racing applications aftercoolers packed with ice work very well because they only need to work for around ten seconds or so (hopefully) before you shut down and head to the victory podium. For milder racing and street applications air/air intercoolers or aftercoolers with radiators are more practical as their ability to cool incoming air is not reduced with time.
When is it right to intercool?
Obviously, intercoolers only work with supercharged or turbocharged vehicles where there is a substantial difference in temperature between the air entering the engine and the cooling medium (the intercooler). Because superchargers heat up the air significantly as they compress it, it is possible for there to be a very large temperature difference between the intercooler (ambient air temperature - 80F degrees or so) and the compressed air (200F - 350F degrees). Superchargers with higher boost will create a hotter discharge, so as you increase your boost, the effects of the intercooler become more and more noticable. In general we would not recommend intercoolers on supercharged engines with less than 8-9psi of boost, as the benefits will not be substantial. Essentially, run an intercooler when only when you running peak boost (i.e. any more boost would cause detonation) for the octane of fuel you use. Intercoolers work well in both warm and cool climates and work exceptionally well on marine applications because of the easy access to cold water.
Don't intercoolers restrict the flow of air into the engine?
Yes. Any time there is an obstacle in the way of the air flowing into the engine (like an intercooler fin or louvre), a pressure loss will result. Today's intercoolers are very effective in minmimzing this pressure loss so that the benefits obtained by cooling the discharge temperature normally outweigh the 1-2psi (approximate) loss in air pressure, which can be regained by running a smaller pulley and increasing the output of the supercharger.
The final word!
So while intercoolers work well on higher output superchargers, they are not recommended for lower boost level kits, like an average 6psi street kit. If you're looking for exceptional performance from your engine, consider adding an intercooler to your engine, or consider purchasing a supercharger kit that comes with an intercooler. Most ATI ProCharger systems include intercoolers and still remain very reasonably priced. Paxton has also recently introduced several intercoolers to fit their more popular supercharger systems, while Vortech already includes intercoolers with several kits. Good luck with your intercooling endeavors, wherever they may take you!
this whole thread is kinda dumb. you need the MAF placed correctly and you need the plate setup to get you to be able to pipe to an a/a intercooler, that's it.
matters of pressurizing the piping is pretty negligible, you'd fill it up before you could even think about it. it's a non-issue.
get a plate setup to work, then go from there.
Thanks Brian.
I've always seen that the Holden guys don't do too bad with them.
*Inb4Joshweldsboltsintosomething*
Not from what I have read... Water to air will only get as cool as the hot water... where as air will get as cool as the ambient temps of the air. Plus W2A has more danger involved with it.
w2a is by far more efficent per size... The water is able to absorb much more heat for a much longer time, and it also cools much more effectively... Think of it like a big battery vs capacitors in an electrical system... w2a being a big battery that stores alot of cool.
The problem with w2a in m90 stuff is the fact that you really need a core that is twice to 3x the size as what even the bigger cores provide to keep the high flow and super cold intake temps. On my 400whp turbo setup I used the equivilent of 8 or so SSIC's worth of intercooling.. on my current 600whp setup I am using 2 of those intercooler cores...
You will need to incorporate speed density tuning into this to get it to work properly, which is not possible to do on these cars without a standalone or some hook-ups with the guys that created Tiny Tuner.
running speed density isn't all that difficult to manage.
however, i feel like you could easily run a MAF in the system and not have any issues. it just matters where you place it.
Hahahahahahahaha.
Just thought I'd quote this. Funniest thing I've heard all day.
So how exac..hahahahahahahahahaha
Sorry, still laughing. I can't hatalkhahaha
all i ever heard from people living in america is either a "can't do it" or "won't do it" statement. has anyone ever done it? not that i've seen.
and you...really? do we need to keep at this? you're literally my least favorite person on the entire forum right now.
I would invite you to show me how you "can do it" since you stated that it's not difficult.
I'm not here to be your favorite person here. I'm here to correct your lack of knowledge.
based on the sole fact that i dont even own a wbody, i have no way of even attempting to prove anything to you. however, the theory behind speed density only goes so far when you can still run a ****ing MAF with an air to air intercooler. you dont need speed density to pull this off, you just cant be stupid.
But it's easy....I don't own a LS1, but yet I can prove that they are able to be easily converted to SD only.
What am I missing here?
It's ok to admit that you were over your head and shouldn't have typed what you did. That's the great part about being an admin. You can change your posts, along with mine.
