Air bag light
oh, makes sense. the plug was blue. what about this? this fuse is missing:
it says seat fuse, so i was thinking since the airbag module was under the seat, then mabye thats the issue? might be a stupid question. just wasnt sure if theres supposed to be a fuse there.
i feel ya, my right blinker quit today, i swapped the bulb, and that was as far as i was going, i was dripping, just standing in direct sun, it had to be over 100 on the street. i quit with no results.
i just went to play with it again, its a reasonable 86 right now outside, lol so i played with it some more and fixed it. dirty connection.
My blinker was just doin that. A cleaning fixed mine as-well. But I'm thinking clock spring. Is the wheel a pain to remove on these?
dont know about the gp air bag removal, but after the bag is off its all gravy. the clock spring has a clip ring holding it down, and 2 zip ties on the harness, that the yellow plug under the dash by the obd2 port is where it plugs in.
when the wheel comes off, watch for the radio control wire as well it un plugs under the wheel and the wire is in a clip.
i also took the plastic off around the column.
the regal i used a small 2 gear puller to pop the wheel off. again not sure what the gp looks like or what puller will work best.
