Aftermarket bushings
  • Thread starter Thread starter TDCRacing
  • Start date Start date
T
TDCRacing
Guest
So i am going to be doing my brakes,wheel studs balljoints, the whole 9 yards. are there any bushings that i could replace with like poly bushings (energy suspension) or something of that nature...like for the sway bar ect?...or maybe just replace them with new stock ones? if so wich ones usually wear out and where can i get them from if there aftermarket? thanks fellas!!
I see now zzp has a swaybar bushing kit...any other bushings?
Thats pretty much it I believe, unless you want to replace the LCA bushings, but there's no poly bushings available for those that Im aware of. You could do your endlinks though (the thing that connects the sway bar to the LCA if the ZZP kit doesnt come with those already.
Do you think it would be worth the 25 bucks if those were worn?
It's not common, but the LCA bushings do go bad. They aren't expensive, and you might want to inspect them while you're in there.
I actually looked at the prices and yes pretty cheap.Might as well change them
