Aeroforce Scan Gauge
has anyone had any play time with this..
MSD DashHawk Vehicle Information Display - PFYC
can the aeroforce do a cylender misfire cycle?? would that be a pretty handy feature to have?? with out a tunner there is not much i could do about it tho.
just wondering what yall thought about it
It will display total misfires. You can go to Interceptor OBD2 data stream gauge and scan tool by Aeroforce Technology and download the manual. It lists the available options.
this is what I am planning on doing as well. I ordered a boost gauge and Oil Pressure from Prosport I can not wait to get them in I ordered the Pillar 3 Gauge pod too. I am not sure what gauges I want to put in to the spot that you have your AF and Trans temp I was thinking Transtemp and Something eles. What is good about monitoring your AF
its the same idea as other gauges...to watch whats going on in the engine as well as to monitor if anything goes wrong...hope that helps
The Aeroforce can list your misfires by individual cylinders all at the same time.
How does it fit all 6 cylinders on that little display at the same time?
I can't see misfires anyway since my P0300 has been disabled, but just in case I need to re-enable, how do you do this?
It lists them like this...
Cylinder #1: 0
Cylinder #2: 0
Cylinder #3: 0
Cylinder #4: 0
Cylinder #5: 0
Cylinder #6: 0
And I think the last couple lines are all "X" because it's also available for V8s. It can fit it all just fine...
I am going to be adding an Aeroforce Gauge to my 02 GTP, can I get the power required through the cigarette lighter by the way of a plug?
