98SilvermistGTP
I have an aeroforce and boost gauge. I wired the power wire for both of them together and ran a wire to a 12 volt source. Is this okay to do or should I have ran a seperate wire for each gauge made a seperate connection? For some reason, the gauge turns on and stays on for about 5 seconds and then turns off. It says annuciator not set up right before it turns off. The power source I used is a hot pink wire under the steering column that I read in a how to post about installing a gauge. Is this not a good 12 v source? If not what is a good one?
Thanks for any help.
