ShadowSwept
So I know the easiest way to install the scangauge is with an add-a-circuit, but say I don't mind splicing wires, would there be a good wire to tap near the A-pillar?
This.use an add a circuit and tap it into the fuse block next to the glove box. when I did it, I used a wire that had multiple strands, so when I added more gauges I already had power run to that area.
Find "ignition hot" in the ignition harness. Easier to go to the fuse box though.So I know the easiest way to install the scangauge is with an add-a-circuit, but say I don't mind splicing wires, would there be a good wire to tap near the A-pillar?
Red or pink?Find "ignition hot" in the ignition harness. Easier to go to the fuse box though.
Pink.Red or pink?
Yes and yes.Most say to use the window fuse with that install, couldn't I tap the same circuit near the driver's door, or maybe splice into the gauge harness?
It is an '03. A pic would help if you have one.Do you have a 97-03 grand prix if so there's a unused plug under the glove box you can buy zzp's drop down harness that plugs right into it worked great for me. It's running to its own fuse to safest easiet way to do it. There's 3 wires on the plug ground, constant hot, and accessory hot which is the one I hooked it to so it turns on and off with the car. You have to pull the little jumper fuse out of the back of the aeroforce to. I just did mine last summer if you need a picture of where the plug is let me know.
Sent from my SM-G920V using Tapatalk
