traildog
Banned
That's not the right grommet then. From inside the car it's up even higher, and slightly closer to the driver's side. You just have to pull the carpet down a little bit, and reach your arm up under the rubber padding, there's a stiff cable going through there (think it's the hood release, but I can't be sure)
It's got a round rubber plug that you can either pop out of place, or you can puncture to feed a wire through (I used the prior option)
^Where the red power wire is going in.
I didn't see that one.
There is a floor gromment on the passenger side, that has a huge harness going through it to the under hood fuse box/battery location. I use that one because it's near the exhaust.
So, I need to punch a hole big enough to get the connector for the sensor through. Maybe just s slit.
Sorry for all the dumb azz questions. I'm learning as i go......
