Adding HUD and a DIC to your 97-03 GP
im trying to do this mod to my 99 gp but i dont know where to find the harness, can anybody tell me where i should look for it? its a 99 so it should be there right?
99s don't have the harnesses. only 97s and 98s have them because GTP was a factory option on GTs for those years, rather than being a model of its own.
i do believe. if you whip out your DIC and look down to the side near the glove the harness would be there. the HUD switch harness would be inside the dash. take the instrument cluster out and it'd be down to the right about where the switch would go.
Ive got a question I am trying to install a hud on my 99 gt and the plugs I have to got to the hud switch is a 6 pin plug that has only five wires in it and the wiring chart shows that there are seven wires to the switch and the switch has seven pins? do i need a new plug?
every company and gm says theres a difference in the glass between a hud car and a non hud car though. can u see the hud on the glass?
isnt the windshield glass between the hud cars and non hud cars different?
Technically the glass is different because there is a little reflective section within in the windshield so you can see the HUD better. I know this from looking at a windshield with HUD and Non HUD. You can still see the HUD on the normal windshield though.
Ok. So I have a 1997 GP GT and it has a 2000 engine in it. Would I still have to buy the '97 DIC or can i go with the '98-'03?
depends wether you are still running the 97 pcm or if you are running the 2000. If you are still running the 97 pcm I have a digital dic. If you are runningthe 2000 pcm you will have to find the 98 02 dic that does not have tire pressure on it.
I posted something earlier but I don't think it showed up. And if it does and i don't see it i apologize.
I have a '97 GP GT with a '00 engine. Will this effect what DIC I need? Do I still need to buy the '97 DIC or can i get the '98-'03 DIC's?
Have looked but cant find anything. Can a 2000 GTP HUD be installed into 04+ GP??? What are the differences???
