Aces Budget BLOWN White Trash Car COILOVERS IN (MY GARAGE)
Re: Aces GP Budget White Trash Car
how to flush coolant.
remove the t stat, put the t stat housing back on, take the upper hose off the radiator, then push it down to the ground to a bucket or let it fly.
get your garden hose out, put it in the rad turn it on, then fire up the car, let it run till clear water pumps out the top hose.
then turn the hose off, run the car till no more water comes out the upper hose. then turn it off.
put your t stat back in, with new gasket, the upper hose back on.
now take 1 gallon of full strength green antifreeze, not the 50/50 crap. ( parts store cheap green is fine to use) dump the whole gallon in the radiator, fire up the car, fill the rad with hose water till its full. top as needed till its ready to be bled of air. it will burp and take coolant as the water in the block warms up the t stat opens up for a few seconds till cold coolant hits it and it shuts again.
now to bleed the air out, let it idle rad cap off till the fans turn on, (when the fans are on the temp is over 195 deg, the t stat is wide open) then open the bleeder screw on top the t stat housing a few turns till a steady stream of coolant comes out the hole, shut the screw, top off the rad. cap it.
done.
Thanks Scotty I think my tstat is sticking it got real hot on my way to college. And I know the flush the dealer did when I first got it wasn't perfect. So I'm gonna reflush it. And I bought something extra special today for a deal
Drilled T-stat kills economy because 180* operates at a low temp?
NOW THAT is full of laughs.
You'd lose more MPG's driving like a douche than deleting the EGR and running a drilled 160*.
As humid as Missouri gets, I ran a drilled 160*, and that car of mine still touched 180* in town.
Gp got a deep leather condition today. The drivers seat I had to do twice because it absorbed it all very quickly.
Izzat hog lard or bear fat? Just kiddin! Tis awful shiny but I bet it smells good in there. Anything beats 10 year old GP carpet pad smell lol. You ever find that cat who run you into the rail? Get the door to clear the fender and rub off marks?
It takes a couple hours to soak in. They say don't drive for 4-5 I won't be driving it till Friday anyway
