Aces Budget BLOWN White Trash Car COILOVERS IN (MY GARAGE)
Aces GP Budget White Trash Car
I was looking for a Monte before I bought the GP just couldn't find one within my area that wasn't either overpriced or completely trashed
I just found one with low miles being 67k for 10k I think that's over priced imo this is also a dealer
Re: Aces GP Budget White Trash Car
Yup way overpriced. I looked at one years ago that I seen online and wanted (dealer) I go to look at in person.. Open up the door and I see used tissues just sitting in the backseat. Closed the door and left didn't bother to get the keys and even look at the rest of the vehicle. Shortly after found a red base model GP but then I remember the comp g that was at the local dealer that was cheaper then the base model I had just looked at and had lower mileage. Winner winner chicken dinner
Happy Easter to me. Seems as tho the first step is to replace the gas cap that's coming up on the dic too. I read into it a little and I hope it's none of the sensor vull**** in the tank or on the filler neck. My car I don't have the access panel.
It could be the vent valve solenoid too if the new gas cap doesnt fix it. But alot of times you'll get a P0449 code aswell.
That's the only code
EVAP is dumb. Delete it, and the codes too.
Who needs emissions anyways?
I agree. Except. PA is dumb
thats one of the many deleted codes in my pcm.
Clay has dhp and I have an 05 pcm so I'm gonna try and have a bin set up when he comes back out again to flash he is learning
deleting codes is child's play lol im sure hes got that down by now.
i deleted my egr, evap and rear o2, in all thats like 12 codes. cause i deleted every last code associated with each. the egr and evap are still plugged in and working as they should be. the rear o2 is not even plugged in any more. its just got its pig tail tucked up in the heat shield.
I just want po420 tuned out. And if a new gas cap doesn't take care of that. That'll have to go too. Maybe you could send him your bin to look at since it's an 05pcm tune anyway
dhp reads the bin the same, its best if he reads your pcm, then deletes the code, and flashes it back.
your a 06? 05 maybe the cut off date for dhp. and most who use dhp on a 04 up are best off using a off board tuner set up to avoid bricking the pcm.
yup says 05 last. https://spreadsheets.google.com/pub?key=pd4_K-aWZn1_K034oyJoMUQ maybe time to run a 04 pcm? or fix the code lol
That's what I mean I have an 05 pcm and he has an off board. So I can be tuned I talked to overkill about it he confirmed I can use my 05 pcm to tune my car.
in the past the jack ass at the pump didnt make the cap tight, the light came on, i made it tight and with in a minute or two the light went off on its own.
We don't live in a communist state 😉 we pump out own gas lol and I checked it 4 times two diff days just to make sure it actually needed replaced lol
I'd really only consider the only communist state to be commiefornia, and new york trailing behind it haha.
Maryland is close behind it I have a friend that's a teacher there. And pa honestly isn't far behind. Next step. I'm moving to a state with no emissions lol
