AC Compressor
JoeBoxer1130
So I recently purchased a new battery for my 2004 Grand Prix and the following day I have no cold air coming out.
Fuses and relays are good and the clutch works when I attempted to add more Freon. But no cold air comes out.
I don?t hear or see any leaks on the lines/hoses.
The temperature of the air does change to hot air when moved.
Does this mean it?s time for a new ac compressor???
Any tips will be greatly appreciated
Without throwing a set of gauges on the system you're just going to be guessing. If you don't own a set then I would take it to a shop and have them check the system. It could be low/empty/leaking. I went through this on my 00 GT. Found that the compressor itself was leaking.
