abs wire harness?
mo1040
Well here's the story... was replacing my rear hub on my 2000 grand prix and forgot to unplug the abs connector and tore the wires out of the plug... does anyone know if you can buy a new plug and splice it in or is it off to the junkyard to look for a used one???
Cant you disassemble the plug you have and re-wire it? Unless it was injection molded. Then Best bet is the junk yard.
I thought about fixing the plug...the two pins pulled out of the connector so the wires are not torn but I don't know which wire went where in the plug...I think there is a tan wire and a black wire?
Ran to o'rielys and they said $95 for the plug and then looked up a dorman plug for $35... Yea fixing the plug was a pita trying to get the pins all the way back in...the tan wire went on top, when I had them reversed the traction light and abs light was on but all fixed now and good to go.
