ABS/trac off lights on - 2002
hockeyrocks
A local shop hooked up the scan tool and said the scan tool and brake module were not communicating with each other. Any Ideas? The shop said they could start trial and error fixes at $85 an hour. What can I try on my own. I usaully can handle most avereage mechanical/electriacal work myself. What should I do next???
99percent of the time when those come on together its a ABS tone ring problem wich is fixxed by replaceing the wheel bearing where the tone ring is bad or could be a sensor itself , without knowing what kind of scan tool they used they could be BSing you
Fwiw my car has a similar problem. I've replaced the bearing. Try as much of a pain in the as that it is try the EBCU. Go to morad, it's about 200 bucks. Look into that. Hope this helps.
i've got an 04 gtp have both the abs and traction lights on was told it was my hub so i replaced both of the front hubs and still throwing the same lights any ideas for an 04?
Could be the same thing. The EBCU brakes in most w-f bodies from what I've read. Definitely do some research on it. My car is definitely the EBCU, l maybe it's the same for you guys. i'll try to get the codes so you guys can compare
C0244 PWM Delivered Torque Malfunction, C0550 ECU Malfunction
These are the codes i got maybe you guys have the same. If you do its definately the EBCU.
this happened to my car as well i had to change the passenger front hub assembly and that fixed it,but now it happening again n it sounds like my front driver side
