Comanche1959
I've read many, many ABS posts here and they all sound similar but a little different than my problem.
Symptom is intermittent ABS & TCS Off lights with the steering going a little stiff. I pulled all 4 wheels, checked the plugs, wires, wheel hub play (RF has a "tiny" bit of play). I put a dab of dielectric grease in the connectors, & put them all back. Test drove - problem still there.
Took it to a good garage (non-dealer) and they told gave me the codes below. One other incidental problem / code was to replace the thermostat which they did. Garage owner suggested I take it to a dealer for a better ABS scan so I can get a more detailed idea what it's pointing to. I don't have a problem doing that, but thought I'd post here first. I also checked out Cheap ABS.com and they said they'd do the module for $110.
What do y'all think? :th_wtf:
'Manche-Dude
Codes from the Snap On analyzer they have:
C0550 - EBCM / EBTCM internal malfunction
C0244 - Delivered Torque Signal Fault
C0896 - Device Voltage Range Performance
P0128 - Coolant Thermostat (replaced today)
P1571 - TCS PWM Circuit No Frequency / Signal
'Manche-Dude
