brandonl2000
Well replace the hub assembly for RL and go from there..
just got it on a scan tool the other day, came up with Left Rear Hub and Speed Circuit Assembly, and after that, my transmission is now shifting very slow between every gear, idk what i'm going to do with this thing
I used the scanner on my car too and it said that the control module was bad. I didnt want to apend over $200 so i looked at the wire harnesses on the left and right axles and found both wires had been broken clean through and had been rotting out all the way up the harness. i just spliced in some new wires and the abs and trac light went off and havent come back on.
Yep... same thing happened to me. Interesting it was one wire that "rotted" pretty much all the way to the ABS module. Spliced in new one problem went away.
Wondering if there is something defective about the wire insulation they used....
My ABS light came on, but I believe it was the result of knocking off a brake sensor.
If I don't feel anything wrong should it be okay? I'm gonna scan and see what it says, but otherwise?
knocking the plug off wont do anything if its plugged back in, car running you pull the plug, the abs light comes on, plug it back in, lights of instantly.
you can try to clean the plugs, and then grease them with di electric grease, and inspect the wires along the lca's for damage.
and test the hubs for play. if you have lots of play theres your abs light.
if you have no bad symptoms, the car holding back or stiff steering, drive a way.
when mine was lit up all the time, i had no symptoms at all, the brakes just locked up, and the wheels would spin if given to much gas.
