GTPpower
Keep in mind that if you switch to the l36/l26 intake, you will need to switch to NA heads as well. You can just use l36 fuel rails too at that point. The only advantage if logs at your level is to clean up the engine bay.
And 60# injectors will supply enough fuel on premium to get you into the tens. However, I usually just recommend 80's because they are almost the same price and you have room to grow if you switch to e85.
