If you dont plan to solder to your ignition wires, you may want to buy an "add a circuit" and just go to your fuse box in the glove box. (you can find them at autozone, but the link is so you can see what it looks like.
Amazon.com: Littelfuse FHA200BP ATO Add-A-Circuit Kit: Automotive
I just think its faster to solder to the ignition harness, and you dont have the run the lines as far. But if you dont plan on soldering, then you will want to go that route.
No, you only need 1 constant fuse and 1 switched fuse. You just pop in the "add a circuit" and tie in all your gauges constant lines to the constant fuse. And tie in all the gauges switched lines to the switched fuse.I need 3 constant fuses, so thanks! Right now the car is in the shop to get fixedbut when I get it back I'll take a picture for the dimmer wire that I need to t tap into. I just wanna make sure I know everything before I just start messin with wires. Just double checking since your helping me out Alot
