A/c problems
I got a 2000 prix gt 3800. I have replaced the compressor, the lines that run from compressor to dryer (ac hose assembly) had it professional shop charged it and it is holding presser but wont blow cold and all ac lines under hood are hot instead of cool are cold
if you didnt change the orifice tube, that could be the problem.
the fans are coming on with the a/c right? the radiator fans that is.
Yea the radiator fans r coming on . But the motor has been running about 215 and it usually runs around 180 ish. No water leaks I think that is thermostat. Would that make it no blow cold . I have also changed the flap that changes the air over . But I don't if the thermostat wouldmake it not blow cold or make all the lines under the hood r really hot. Meaning a/c lines.
