A/C dual control question
02 GP GT
I have an 02 GP with dual temperature control. With both setting on cold, I get cool air out of the passengers side and warm out of the drivers side. Can anyone tell me what my problem is and what I need to repair or replace? Thanks in advance, Bill
The air goes where I want it, ie, floor, floor and chest, defrost. The problem is the passenger side will blow cool but the drivers side will blow warm. If I move the slides up to hot then both sides blow hot. Just am not getting any cool or cold air out of the drivers side vents.
The drivers side blend door actuator is shot. Been through this on an 03 Imp 2 times now. Have to lay on the drivers side floor and look up behind the dash along the airbox. You will see a small black box attached to the airbox with a small wire lead on it. Think its 2 or 3 screws. Remove wire, screws and pull the old one off. Take a look at the new one as the shaft it lines up with is flat on one side. Swap in the new one and test.
Thank You very much FordMan. I have been busy the past few days but will climb under there within the next few days and hopefully find what your telling me and get it replaced. Bill
