I'm back!!
Sorry for the huge lag in updates, haven't had too much time to work on it until these past couple weeks and we've been trying to tie it up so I haven't been posting any updates.
Everything's all tied in as far as lines go, and fluids are all filled. We were filling all the fluids, and went to check the oil level... and we're searching, and searching, and somehow we forgot to put the dipstick and tube back in! So after we looked around the garage for an hour we concluded that some little green men had snuck in at some point and stole it, so we just ordered another one. :th_laugh-lol3:
The one thing I'm still missing is the electrical connector for the bosch pump, but thats on order and should be spliced in this weekend. Here's a picture, pre-dipstick lol.
Well that was all last week. Yesterday, I got out there put the new dipstick in, drained the oil to make sure nothing was floating around in there from the dipstick hole being open this whole time, and filled it back up so we could finally hear that engine start up. Go to crank it, and the starter won't turn over. Double checked all the wires and **** and decide to just run a jumper wire to the starter to get some oil primed through the engine. After that, we decided to try and start it while jumping the starter, so I put the fuel pump fuse back in and go for it, and nothing!
So we sit back and scratch our heads for a little bit, until I remember.. the security relearn! Do that, wait 40ish minutes :th_beer-slam:and now it turns over with the key! But still no start
It sounded like it wanted to fire up a couple times, but no luck. I've got spark on 1,3, and 5; and I've got 50psi at the fuel rail. Plugs are wet, and the exhaust smells like gas so it's definitely getting fuel. My next step is to get a compression tester and see what that looks like.
Maybe it was just flooded from how much we were cranking it before the security relearn? IDK, I plan to give it another shot after the compression test and see what happens. If compressions good and it still doesn't start after it's dried out... then I have no idea what to do after that. :th_scratchhead:
Y'all got any suggestions??
