99 GTP Trans locks up in reverse
Didge
Hi, I have recently replaced the MAF sensor with one from a 99 Camaro (Same Part number and specs), and suddenly the trans started to lock up going in reverse. Could the two be related? The time between the two happening was a day, and I never had any problems with the trans locking up before. Thanks!
Actually I found the problem. It wasn't the transmission. What had happened was that the caliper bracket mounting bolt (lower) had backed out and disappeared. This caused the brakes to lock while going in reverse. I'm just happy that it wasn't the top bolt, that would have been a scary ride. Be sure to check those bolts are 133 ft lb!
