    TIPS:
99 GTP Partout - Intercooler / GenV 90 conversion / QUAIF Posi Diff *RARE* / etc.
Andy0x1
Parting out my 99 GTP
Built Trans:
3.69 Gears (Not 3.29 GT or the stock 2.93 GTP) Custom PCM required.
QUAIF POSI DIFF *RARE* - Amazing mod. Prior to this I broke half a dozen stock diffs
VAC MELT 300M Input shaft. (originally $500)
Hardened Pump & 4th gear shaft. 04 sprags (not element sprags) Edge Racing TQ Converter / Blue plate clutches + bonus clutch / wavy plate removed / shift kit / hardened sleeved valve body.
Low miles on this trans.
Engine:
Diamond Forged & ceramic coated pistons
Aggressive cam
Roller chain
CTSVR Race lifters
Balance shaft delete
Upgraded crank damper
Ported heads
Pushrods / retainers / ARP bolts / etc.
2.25" Air Water Intercooler w/BOSCH pump
42lb injectors
Gen V M90 (low miles) w/turn down adapter. gutted stock TB with MAF removed and LS MAF for less restriction.
Modular snout w/various pulleys
Suspension / Brakes
BAER EradiSpeed+ 2pc rotors and calipers
GMPP (KONI) adjustable rebound struts
Eibach Springs
Doors / Hood / Interior / Borbet Type E Chrome wheels w/new tires
attachment.php
Located in Minnesota.
Sell just the diff?
That's probably the most valuable component of the whole part-out.
Once I sell any part, I'm committing to parting the entire thing & trans.
It was a $1500 part, and required a good stock diff to transplant the planet gears. Unclear if your replacing an exploded diff or not, but I'd sell it complete - $1k
If you have never driven a FWD vehicle with POSI, but it is a startling mod. Makes the car torque steer quite hard compared to the stock open diff. Also gives you amazing traction coming out of corners, or making a right turn into traffic - you can basically accelerate as if you were in a straight line when cornering. Which also leads to added stress to the half shafts. My car was around 450WHP and broke a fair share of them.
Also; if you floor it on a road that has a crown to it; assuming your car makes a lot of power and breaks tires free at speed; having POSI will make the entire car drift toward the curb while spinning, as opposed to the open diff which goes more straight, and limits traction a bit. (i.e. you basically have to /DRIVE/ the car)
The diff makes a stupid big difference; I've never experienced anything quite like it.
Torsen Differential, How it works ? - YouTube
Awesome let me know if it parts out mine is still good but have broken 3 diffs already and just went turbo and blew up gxp chains on a 1-2 shift under boost so know the diff will be next to explode
