camopaint0707
Banned
Re: My 98 GTP
check the abs fuse.
check the abs fuse.
I like your tips better than the ones I have, you can tell that the outsides on yours are shorter. If you look close at the pictures of mine you can see both tips are the same length.
They do clamp on but I also had a spot weld put on them.Did you have them welded on or do they just clamp on. I noticed some people had to weld there's or get a mechanic to install. I was looking at getting a set myself. Your car looks sharp!
I wouldn't change them to white then you'll look like Palms car. Black doesnt look right. I vote gunmetal !
Lower that thing too, you and Matt both need too.
