97gtpjoe
Ok so my dad decided he wanted a car exactly like mine (I have a 97 2 door gtp) so he went out and bought a 98 gtp 2 door coupe. Well needless to say he brought it to me from TX all the way down to AZ for me to fix, it has a crap lot of problems which I need everyone's help with(I know I could search but I dont know where to start)
So here is what I have done and then Ill list the trouble
I did a whole LIM gasket replacement with tune up new vacuum lines , valve cover gaskets, new starter ,new power steering pump and Antifreeze flush to green stuff
Trouble
1- Car seems to bog on acceleration , when I try to go WOT the car wants to stall , power seems to fade.
2- I replaced the starter with a new one and I get a clicking sound (click, click, click, till it starts .... sometimes it takes a while) I took it to check the battery and I was told its good (12.9 I believe that's what I was told)
3- A/C blower was working fine through all vents before I bled the air of the cooling system now I don't get air through the main vents only the lower vents. I also have a bunch of plugs not plugged in on the passenger floor side by the blower ,I posted pictures on another thread about all the plugs that were loose I still dont know where they go I could see a vac line on passenger floor also which is not plugged in ( http://www.grandprixforums.net/need-help-identifying-ac-blower-plugs-81022.html )
. The vacuum line that goes around passenger strut area of the car was removed so I ended up capping the accessory vac port on the supercharger , any help how I could find this would be appreciated
4- Just got new tires an aligned the car and it has too much play on the steering wheel , how can I fix this
I should've kept my dad from buying a car with all this problems but now im stuck trying to fix it any help will be appreciated!! Thank You
Trouble
