Kejross
This is my 98 GTP I picked up for $750 bucks with a blown motor and the progress I have made with it.
Almost as it looks now... Lowered almost 2" and running bigger tires(only on the front til the backs finally wear out) other than having the tint redone the exterior was pretty well stock here.
The stock motor that was in it when I got it, also chunked a rod through the oil pan and bent a couple valves
Then I replaced that with an 06 L32 80K on it when I installed it. Pretty well stock in this pic aside from the obvious
Then I did 12" W-body brakes off a police impala. Powdercoated and rebuilt, and stainless lines, 5th hard line. Did that when I lowered it with GR-2's and rear sway bar with poly moutns, front poly bushings on LCA's and sway.
