97 GTP Tuner questions
It's a ZZP ICCU as it says on startup. You can adjust timing, fuel and a few other things. The Maf Hz is the frequency you are hitting on the maf. The higher the frequency, the more air is coming through the engine. You can also adjust your timing throughout your rpm range. Right now it is set to pull some timing, which is probably good until you can monitor knock.
