97 grand prix won't start
I'd get to checking what Bill said, but if the LIM/UIM need attention I wouldn't let it get behind ya, those are pretty important.
Thing here is..something has to be missing or bad.
You can't have compression fuel and spark with the correct timing w/o it starting. So some sensor is likely holding you back.
I agree with both of you, just don't have acess to the car right now til probably tuesday and yes the plugs were pretty drenched in fuel when I changed them.
Ok, then either you turned the key on and off a ton w/o it starting (primes every time you go on from off) or something is causing you to get too much fuel on prime.
It was cranked over alot by the owner and her brother and neither knew about it priming every time you turn the key on.
