96 grand prix bolt torque for shocks
95grprixse
What is the torque for the two bottom shock to knuckle bolts and the two top shock to body bolts?
96 Grand Prix SE 2 Door.
Thanks.
Tight.
I'm sure the ones on the knuckle are nearly 100ft lbs and top ones are 30-40 but just blap em with a gun or get them really snug.
I've never torqued one of those bolts ever.
Yea, I put the shocks on a few days back. Sounds like the left rear is rattling/making noise. I am guessing I did not get it tight enough, or I hope that is the problem. I have changed out the shocks on three different grand prix's a 95 and now this is the second 96 I have changed. Never had a problem with any before, but I can't help but think maybe I did not get it tight enough. Thought it might be good to know what they are suppose to be tightened to. Could probably strip out those top ones if I torque on them to much.
Yes I will check it out. If I recall they are mounted to the lower strut mount/bolts go through a clamp that holds the stabilizer/sway bar.
