    TIPS:
87 to 03 grand prix front sway bar and gas door :)
sasquatch094
need a front sway bar, aftermarket or stock is fine...
and a gas door with a good hinge silver in color.. let me know asap.. thansk!
I can install it in 20 minutes. I've had practice and done a few if them. Some will say it helps if you lower the cradle, but I've never needed to.
I have your gas door. It came off a brand new 2001 GTP rear clip I installed on my 1997 GTP. Its white in color.
I kept my 1997 door because it has the gas cap holder built into it.
Let me know if you want it, and what the shipping address is. Just shoot me a PM.
As for the front sway bar, ya once the old one is out, usually the drivers side wheel well works the best, the new one slips right in same way the old one came out. No need to lower the engine sub frame what so ever. You might also want to look into buying new end links, cause 95% of the time, the bolt holding the end link together/in will break when you try to remove it. Rust city on that bolt, regardless where you live. Be sure to coat the ENTIRE new bolt with anti-seize to prevent corrosion. You will thank yourself later next time you need to remove it for what ever reasion.
~F~
