7 codes.....yay....not... HELP!
deadsnake
Hey guys, having some issues here, your help is always appreciated. Replaced the rear o2, whole TB including the sensors....
I have the following
(these codes appeared after the swap)
p0713
p1571
P0443
p0141
p0135
p0125
p0102
Any ideas guys?
what did you swap from? then into?, year of car all that good stuff. not sure what to pick in the sig lolDTC P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input 5 you change the trans too?
p1571 abs problems. hub or wires maybe.
OBD-II Trouble Code: P0443 Evaporative Emission Control System Purge Control Valve Circuit what engine did you swap to? you cange the evap.or forget to hook it up?
OBD-II Trouble Code: P0141 Oxygen O2 Sensor Heater Circuit Malfunction (Bank1, Sensor2) checked the o2 wires?
OBD-II Trouble Code: P0135 Oxygen O2 Sensor Heater Circuit Malfunction (Bank1, Sensor1) same thing really, as above it seems.
OBD-II Trouble Code: P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control temp sensor, it it plugged in? its under the t stat in the lim.
OBD-II Trouble Code: P0102 Mass Air Flow (MAF) Circuit Low Input and a good old maf code. clean the maf, check the wires, or maybe its dead.
Just the rear o2 code, I can't remember what it was, missfire, 500 RMP idle, running very rich (13 MPG) also lights dim bad when I go in reverse
this looks like a post for Mr boost lol its a rough one for sure. im at at a loss here. unless all that stuff just went bad at once. seems unlikely.
Having so many codes typically means a power or ground issue. Do some searching for schematics and I bet you find they all have a common ground or a common power supply.
You might be able to fix this up with one fuse or ground wire :th_thumbsup-wink:
Ah darn it, I am so bad at that too....I do know I have a bad thermostat+ my waterpump and LIM are leaking coolant.
