55w hid kit wont turn on
nascartech
hi i am having a problem with my 55w hid kit when i turn the lights on they dont turn on i know the kit works cause it was in my old gp and my dad had it in his van while i was looking for a new gp i heard i might have to run a bigger fuse in the under hood fuse block also this is a 97 gtp my old one was a 2001 gt
You should get a relay harness since you are using a 55W kit. That should solve your power on issue.
well i found the problem i do need a relay harness i ran wire straight to the ballast and it turned on so i guess ill oreder the harness and problem solved
