Thanks for the response; do you know what boost levels that was and the turbo if you will. I have tried doing searches on clubgp but that is a headache. You older forum members probably can remember instead, my buddy is trying to go turbo but will rather do straight line stuff.
Yeah I was going to say the same thing, the problem is those are getting really hard to find now a days with the proper wheel and type of housing (garrett tang style). My buddy's dad has a GN and I know for sure the turbine is a t3 with God knows what type of exhaust wheel, but I know his compressor is about t4 66mm wheel
I can't remember the boost levels anymore ... i'd say 15-18 range probably.
I am no expert on turbos.. But this was my thinking on my build when I was at it...
I had the ST5 cam.. biggest ZZP sold. (Small compared to blower cams)
I was going for track usage. Street usage not much at all.
I was going to be spinning some 6500+ RPMs due to the cam.
I had PLOGs. (Others have gotten great numbers)
I had 2.25" cross over.
I had some yocal ported heads with springs.
I was gonna use e85. (helps spool quicker)
I had a 200k mile L67 ... so lower compression but strong..
Exhaust velocity did not seem it was going to be much of a problem to get a 65mm exhaust will a spinning ( i think it was 65mm.. been awhile )
Spool was pretty damn fast and just kept going.
My car is lighter... ~3100lbs at max, without a driver. So that helps get it moving.
Once I started to get the 60 foots decent, I could hit high 10s at 15psi.
With the ST5 cam, it was recommended to rev it out pretty high. If I had ran 150# springs instead of #130# , results might have been a few ticks better before converter slip killed me.
With turbos so much better compared to 12+ years ago when people start to finally slap turbos on and see what happened. Lot of guys used pretty small T3's and couldnt break 400whp.
The T67 did 529whp @ 17psi like it was nothing. And this was with mostly going by paper, and then slapping it all together and see what happens as my first turbo anything.
Had I been smart, and kept eye on TCC slip, I would have realized how much power was getting lost.. Once above 17/18psi, TCC slip was out of control at over 1000 slip over 20psi.
Guys at ZZP were surprised I ran as well as I did at the track.
So I guess with that, my feelings are, go T4 its a bit bigger than A T3 .. but not monster... but the 3800 will be fine with it.
Go with a good turbo line that is not known to be lazy spool.
Also from what I've been told by the techs at Precision, I was told their HP Number ratings, are for the highest AR sizes. And that smaller AR the max HP goes down. But they didn't give any good rule of thumb of that that may/could be.
Also remember, 20psi from one turbo setup does not equal the same as 20psi from another turbo setup. So always keep that in mind. As A similar setups to what I had, but with the cartuning kit and say 2.5" downpipe, put down like
505whp but I think he was at 22psi.
