bobeebob
Its just one problem after the other with this car :th_angry-censored:
After replacing the short block due to low oil pressure i was finally able to test the transmission i rebuilt myself.
Mods on the tranny are as follows: 3.29 gear with 7/8th chain, hardened 4th gear shaft, and intense shift kit.
Everything work great except the surge i get in 4th gear. With the Tech 2 im able to command the TCC solenoid; and in 3rd gear it works flawlessly under any load.
But in 4th gear whether im commanding the solenoid on or off im constantly getting the surge at any load. Btw without commanding the TCC solenoid, it doesn't go above 50% duty cycle
Also i noticed in the adaptation tables, two of the readings were out of whack. (this is after resetting all tables)
Steady State TAP 4GR : 93.98 psi
Steady State TAP 4GR/TC : 10.00 psi
Only thing i haven't gotten to is to hooking up a pressure gauge to the trans.
I am completely sure that the surge is not a misfire from the engine, but for good measure i cleaned the MAF and ran seafoam through the engine.
Right now im leaning towards improper install on some seals but i sure hope not
